1. The TOOL-00002 was placed on the trailing edge of the right side propeller blade 2.The level resting on the canopy deck was picked up without changing the orientation to attached to the TOOL-00002. The angle was 71.2 3. The level and spacers were removed from the propeller. 4. The propeller was rotated 180° 5. Repeat this page and 47iS/U-08 to set the pitch of the other propeller blade. 6.The blades should be within 0.1° to each other
