01/02/20: 0.5Hrs 1. The Gnd Starter Relay wire from the Regulator A bundle was cut and sealed with heat shrink.
01/23/20: 1.33Hrs 2. All of the regulator A ground terminals were attached to the bottom of the fuse box. 3. The Fuse box was temporarily installed to the firewall. 4. The fuse box lane A and B were installed into the fuse box. 5.Generator A and B cables were connected to their corresponding connectors on the fuse box.
