1. SEAL-00002, C-0122-L & -R, a 5/16 nut driver, screwdriver, straight-slot screwdriver with taped ends., sharpie pen and a C-1219 foam spacer were placed inside the cockpit. 2. With the canopy assembly open, the nuts attaching the C-1201 were loosen up. 3. The end of the SEAL-00002 was pushed into the gap between the canopy and the seal retainer. 4. The seals are fully seated. 5. Tha canopy was closed and latched 6.The seal retainer was pried with the taped screwdriver. 7. The retainer was marked before removal. 8. The retainers and roll bar seals were re-installed. 9. The C-01224A was positioned between the ends C-01220-L/R with the adesive side up. Marked where the C--01224A will need to be relieved to fit. The C-01224B-L was installed to the C-01221-L
