GA Aerospace’s Web Site
RV-12iS B
.Finish
11-15-2019
37iS/U-03
11/16/19 2.3 Hrs
Step1: The lower edges of both L-1 & R-1 forward halves were trimmed to porevent interference with the fuselage skins.
Step 2: The halves of the hinges were cut and sliced to fit in each of their places
The pins and hinges were also bent to give them the desired shape.
Step 3: The end of boh F-01201 J-1 & K-1 and F-12117-L-1 & R-1 hinge pins were grinded to an offset point.
Step 4: The eyelets of both forward asnd aft hinge halves of the F-01201 J-1 & K-1 were beveled using a flat file with smooth edges.
Step 5: All the hinge pins were coated with a dy lubricant.
Step 6: All of the forward hinge halves on the fuselage were installed by inserting thrit hinge pins.
RV-12iS B Home
3643
.Avionics
.Empennage
55
331
.Finish
96
569
.Fuselage
115
758
.Inventory
.PAP
.Powerplant
.Service Bulletin
.Wings
Batteries Log
ECU Cycles log
Painting process
PAP
Powerplant
RV-12iS A Home
