08/06/20 .80Hrs Step 1. Two 3-11/16 [9.4 cm] lengths were cut from the MS21266-1N and installed around the edges of the holes in the F--01273-L-1 & -R-1. Step 2. The WD-01214-L-1 & -R-1 were slided through the F-01273-L-1 & -R-1 and attached to the WD-1215-L & -R.
06/20/19: 0.50Hrs Step 3. The F-01275G-1 was separated into left and right parts. Step 4. The nutplate attach rivet holes and the #30 holes indicated were dimple in the F-01275GL-1 & F-01275GR-1. The nutplates were attached with the indicated rivets.
06/03/20 .50Hrs Step 5. The F-01275G-L-1 was riveted to the F-01273-L-1, F-01275F-L-1 and F-01276-1 with the indicated rivets.The bent flange was positioned on top of the F-01276-1. The same for the F-01275G-R-1 on the right side.
