02/20/19: 0.66Hrs 1. The bushing that sits on WD-01218-1 was chamfered until it fit better on it. 2. WD-01218-1 was inserted into the canopy frame. 3. Tests were completed to check if it could open and close easily, a shim was installed between the roll bar and the wood block but the latching is too tight, a thinner one will be installed.
