01/11/19: 4Hrs 1. HS-1215 was clecoed to the main skins. 2. Two #52 holes were match-drilled into the main skins using the splice plate (HS-1215) 3,4 . HS-1218A-L&R were riveted to the skins and to HS-1206 and HS-1216. 5. The remaining holes on the skins were riveted. 6. HS-1217 were separated. 7. Both HS-1217 were pinched a bit to make sure they laid flat onto HS-1208.
01/14/19: 1.66Hrs 8. A total of 4 #30 holes per rib were match-drilled into them using HS-1217. 9. Both HS-1217 were riveted to both HS-1208.
