GA Aerospace’s Web Site
Date:  8-11-2020
Number of Hours:  3.10
Brief Description:  42MiS/U-15
02/27/20: 2Hrs
1: NA
2: The GPS and XM cables were routed through the firewall.
3: The cover plate and grommets were installed onto the firewall.
4: The GPS and XM cables were roughly positioned where they should be connected.
08/11/20 1.10Hrs
5: The GPS and XM Antenna, EarthX were secured to the ROTAX ECU cables with tie grap
6: the spade terminal was connected to the spade terminal on the wire fron ES-ETX900.
7: Tank sealant was aplied to grommets around the cables and wire.
