02/06/20: 1.5Hrs 1: The Fusebox was removed from the firewall 2: GEA 24 and F-00074-L drill guide were attached to the firewall. 3 & 4: A total of 4 rivets instead of three were removed in order to cleco F-00074-R-1 to the firewall. 5: The #30 holes on F-00074-L, F-00074-R were match-drilled onto the firewall. 6: The #11 holes on GEA 24 were match-drilled onto the firewall, first using a 3/16" drill bit and finishing with a #11.
02/07/20: 0.58Hrs 7 & 8: All attached guides were removed and F-00074-R-1 and the firewall were deburred.
