GA Aerospace’s Web Site
Date:  10-15-2020
Number of Hours:  0.10
Brief Description:  49iS-07
1. The throttle friction assembly hardware was installed onto the BOLT-00005.
2. The F-01245-R was installed.
3. The CT-01206 1/4 KNOB was installed.
4. The throttle lever forward was moved from the aft end of the slot.
5. The throttle arm hardware was removed from the engine throttle arm and the CT-01200 was inserted through the hole in the drilled bolt.
6. The throttle friction was loosen upand full range of motion was percieved.
