GA Aerospace’s Web Site
Date:  4-1-2021
Number of Hours:  2.30
Brief Description:  36iS/U-19
4/1/2021 2.30hrs
1. One of the hinge pin was bended to create U-00007C .
2. With the U-00007D attached to one end of the U-00007C the U-00007C was slided into the two U-00007B. The U-00007D was pressed against the side of the U-00007 and the center of the nutplate was marked on the outside of the U-00007.
3. The U-00007 was drilled #27 with the screw indicated.
4. The length of the U-00007C protruding was checked.
5. The U-00007 was removed and wax was applied to 1 in diameter of the WD 1201-1.
The inside of the U-00007 was roughened, a bead of RTV was applied 1/8 thick and 1/2 in. in diameter to the inside of the U-00007.
The U-00007 was installed on the WD-1201-1.
