GA Aerospace’s Web Site
Date:  2-13-2020
Brief Description:  27iS-11
06/17/19: 1.66Hrs
1 & 2: F-12127H was created by cutting a 7 3/8" length of aluminum tubing, making both 90degree bends, installing the hardware and flaring the tube.
5 & 6: F-12127G was created by cutting a 7 1/8" length of aluminum tubing, making both bends, installing the hardware and flaring the tube.
02/13/20: 0.33
3 & 4: F-12127H was attached to the fuel drain assembly and FUEL-FX375-M, then the hose clamp on the filter was clamped.
7: F12127G was attached to FUEL-FX375-M and the fuel pump assembly, the clamps holding the pump were clamped.
