GA Aerospace’s Web Site
Date:  2-12-2020
Number of Hours:  4.41
Brief Description:  27iS-08
06/17/19: 3.16Hrs
1: F-12127D was created by cutting a 84 27/32" length of 3/8" aluminum tubing, the 25degree bend was made and that end of the tube was flared with its corresponding hardware.
2: The 88.2degree bend was made.
3: The other 3 bends were made and the snap bushing location was marked on the tube.
02/12/20: 1.25Hrs
4: The fuel line was fed forward through the snap bushings on the fuselage, then the forward end was flared with its hardware installed.
5: F-12127D was attached to the bypass fitting assembly. and the tube's clearance with F-12108A was confirmed
6: F-12127D was secured to F-01207D-L-1 with the called out cushion clamp.
