GA Aerospace’s Web Site
Date:  2-18-2020
Number of Hours:  9.00
Brief Description:  28iS/U-03
10/24/18: 1.75Hrs
1.The hole in one side of the WD-1209 brake pedals was match-drilled #30 into the underlying WD-1211-L & -R. Cleco and match-drilled the other side.
2.Both sides of the WD-1209 and WD-1211 were drilled #12, then final-drilled 1/4.
3. The WD-1209 and WD-1211-L & -R were removed and marked
10/25/18: 4.25Hrs
4. Repeated the step 3 on the other end of the WD-01206-1, and assambled.
5.The WD-1211-L &-R were removed and greased then slided into the WD-01206-1
6. The WD-1209 and F-1290 were secured with the hardware indicated
7 and 8 Pending after painting.
12/10/19: 3Hrs
8. The lower halves were removed of the F-1235A & B Rudder Pedals Blocks and then the Pedal Assembly was slided into position in the fuselage as required.
9. The Rudder Pedal Assembly was secured to the F-01201B-1 and the three F-01257.
02/18/20: 1Hr
The pedals had to be reinstalled since they were removed to ease on the fuel lines installation.
