GA Aerospace’s Web Site
Date:  1-12-2020
Number of Hours:  0.10
Brief Description:  38iS/U-22
1. Both wings were installed.
2. The entire perimetrer of the wing was marked for a 3/16 in gap between the wing root snd the fuselage.
3. The gap between the flaperons and fuselage was checked with minimmun of 3/16.
4. With a ultra-fine marker, the body against the wing skin, outlined each wing, top and bottom on the side of the fuselage, the outline of 3/16 in outside of where the wing meets the fuselage.
5. The beveled egde of the VA-204 was align with the outline traced on the side of the fuselage to cover the line.
6.The seal strips go over screw heads and the F-00032.
7. The F-12119C was applied to both wings surfaces.
8. Anti.slip material was applied to the steps.
