Section G5 - Pitot, Static, and AOA System Leak Check (continuance)
The altitude indication was 100 ft One of the static ports was tape over with electrical tape, at the other static ports a syringe was inserted to extract air. When the EFIS indicated 1000 ft above field elevation the stopwatch was started , after one minute the altitude was 1070 ft.
