1. One of the hinge pin was bended to create U-00007C . 2. With the U-00007D attached to one end of the U-00007C the U-00007C was slided into the two U-00007B. The U-00007D was pressed against the side of the U-00007 and the center of the nutplate was marked on the outside of the U-00007. 3. The U-00007 was drilled #27 with the screw indicated. 4. The length of the U-00007C protruding was checked. 5. The U-00007 was removed and wax was applied to 1 in diameter of the WD 1201-1. The inside of the U-00007 was roughened, a bead of RTV was applied 1/8 thick and 1/2 in. in diameter to the inside of the U-00007. The U-00007 was installed on the WD-1201-1.
