03/05/20: 2.8Hrs 1: A #12 hole was drilled into the roll bar. 2: A modified snap bushing was installed into the hole just createed. 3: F-12126 was created by cutting a 30" piece of PT-035X1/4 tube. 4 A piece of safety wire was routed through the roll bar and used to pull the cables through the snap bushing in the roll bar.
03/06/20: 2.1Hrs The wires were rerouted through the roll bar because of a mistake in the manual (42MiS/U-26, the wires must not pass through the Forward snap bushing of the F-01224--R-1).
08/04/20 1.2Hrs 5:The F7139 wire was crimped using an ES DV18-188M Spade terminal. 6: The spade terminal was connected to the center spade of the canopy latch switch.
