03/04/20: 0.92Hrs 1: The spar pin switch and fuel sender wires were secured to an ES-00301. 3: One ES-00301 was riveted to F-01206H-L-1. 4: The roll servo connector was secured to the baggage area under-floor. 5: ADAHRS connectors were routed through F-011206H-L-1. 6: The fuel pump connectors, pressure sensor and magnetometer were routed through F-1207C-L. 7: The fuel pressure sensor was installed onto FLF-00013 and its connector was connected. 8: The fuel pump power connectors were connected as required.
7/10/20 1.4Hrs 2: The COM Antenna Coax cable was routed. 3: The ES-00301 was installed onto the F-01206H-L-1 baggage rib. 4: The roll servo connector was routed through the F-01206-L-1 5: The ADHARS connectos were routed through the F-01206-L-1 6: Both 1 & 2 fuel pumps, fuel pressure sensor and magnetometer connectors were routed through the F-01206-L and into de tailcone. 7: The tape covering of the aft-facing port on the FLF-00013 adapter was removed, then, the appropiate fuel pressure sensor was installed. 8: The fuel pump power connectors was installed.
