GA Aerospace’s Web Site
Date:  7-10-2020
Number of Hours:  2.32
Brief Description:  42MiS/U-24
03/04/20: 0.92Hrs
1: The spar pin switch and fuel sender wires were secured to an ES-00301.
3: One ES-00301 was riveted to F-01206H-L-1.
4: The roll servo connector was secured to the baggage area under-floor.
5: ADAHRS connectors were routed through F-011206H-L-1.
6: The fuel pump connectors, pressure sensor and magnetometer were routed through F-1207C-L.
7: The fuel pressure sensor was installed onto FLF-00013 and its connector was connected.
8: The fuel pump power connectors were connected as required.
7/10/20 1.4Hrs
2: The COM Antenna Coax cable was routed.
3: The ES-00301 was installed onto the F-01206H-L-1 baggage rib.
4: The roll servo connector was routed through the F-01206-L-1
5: The ADHARS connectos were routed through the F-01206-L-1
6: Both 1 & 2 fuel pumps, fuel pressure sensor and magnetometer connectors were routed through the F-01206-L and into de tailcone.
7: The tape covering of the aft-facing port on the FLF-00013 adapter was removed, then, the appropiate fuel pressure sensor was installed.
8: The fuel pump power connectors was installed.
