03/04/20: 2.5Hrs 1: The right side of the harness was routed aft. 2: The right spar pin switch, cabin light, canopy latch switch and ELT antenna wires were secured to an ES-00301. 3: W6075 wire was crimped and connected to the NO spade of the spar pin switch, 4: The ELT remote cable was routed aft from the avionics bay. 5: ADS-B IN connector was routed aft and secured using tie-wraps.
