12/04/19 3Hrs 1. Two BUSHING-BS.245X.375X2 were clamped in a bench vise and then drilled 1/4 through the inside diameters. 2. Using a file, material was removed from both bushings until they fit between the brackets. 3. Using a file, material was removed from the ends of the WD-1212 until they were slightly shorter than the bushings. 4. Both WD-1212 were attached to the WD-1210 as required. 5. The Control Stick Pushrod Assemblies were attached to the WD-1212s and the F-01263A-1 & B-1 as required.
