06/17/19: 0.33Hrs 1 & 2: F-12127J was created by cutting a 2 1/2" length of aluminum tubing and flaring both ends with its hardware installed.
02/13/20: 1.31Hrs 3 & 4: F-12127J was connected to the fuel valve, then to the fuel drain assembly and the assembly was attached to F-12109A. 5: FUEL-FX375M wasa attached to F-12109A. 6 & 7: The fuel filter assembly and fuel pump assembly were attached to F-12111B and F-12111C respectively, then F-12127D was attached to the banjo fitting closest to the fuel filter.
