02/07/19: 5.35Hrs 3. The U WHLNW51CCWHEEL was split removing the bolts. 4. The nut and washers were removed. 5. The tire was inflated slowly then deflate then re-inflated slowly. 6. The main wheel assembly was aplit removing the cap crews. 7. The nut and washers were removed from the valve stem of the U 5:00X5-6IT Tube 8. The tire was slowly inflated and deflate till there were no wrinkles. 9. The bearings were fully greased and reinstalled
02/08/19: 3.83Hrs 3-9 Second wheel 10.Pipe thread sealant was applied to the threads of the fluid fittings.
11/19/19 5 Hrs 1. Final drill was done with a step drill to the two holes of 0.188" which are located at the top of the Assembly Firewall which the holes had to be 3/8" making sure that the drilling was perpendicular to the vertical face of the Firewall Assembly. 2. The engine mount was screwed to the Firewall Assembly using the hardware..
