01/30/19: 15.53Hrs 17:06: All steps, worked on 3 but was not completed. 1. The piece was fabricated
01/31/19: 17.2Hrs Getting a rivet out of the wing and fixing a gap on the right wing tip.
02/01/19: 1.5Hrs 17-06: Step 3
12/02/19 3 Hrs 2. The W-1204D-L was clecoed to adjust it according the specifications and then proceeded to rivet it to the wing.
12/03/19 2 Hrs 3. The W-1204H-L was clecoed to the W-1204D-L and to the W-1213-L Tip Rib. A straight edge was clamped on the top of the W-1204B to confirm that the wing tip trailing edge was parallel to the trailing edge of the wing. Once the placement was successful, the wing tip trailing edge was match-drilled to the wing tip aft skin. Finally the wing tip trailing edge was riveted to the wing tip aft skin, wing tip rib, and wing tip close out.
