GA Aerospace’s Web Site
Date:  11-13-2018
Number of Hours:  7.00
Brief Description:  09iS/U-02
11/10/18: 2.5Hrs
Steps 1 through 5 were worked on according to service bulletin 18-02-02.
11/13/18: 4.5Hrs
It turns out bulleting 18-02-02 does not apply to our manual's version. Back to square one (step 5 still applies and it will not have to be worked on again):
1.. HS-0123A-1 was countersunk #40 in a total of 16 holes.
2. HS-0123A-1 was separated.
3. Two inboard hinge brackets were riveted according to the manual.
4. Two outboard hinge brackets were riveted according to the manual.
6. HS-1209 was countersunk #40 in a total of 16 holes.
7. HS-1209 was separated into 8 parts.
8,9 HS-1209, HS-1212-1 and HS-01211-1 were clecoed together according to figure 6 and riveted using only 2 rivets per spar cap spacer. a total of 16 rivets were installed.
