10/23/18: 3.25Hrs. 1. Fluid fittings were installed into FLF-00014 2. Fluid fittings were installed into FLF-00013 3. The firewall fluid fittings were installed and sealed. 4. The fuel valve handle was drilled 1/4.
10/24/18: 0.5Hrs 5. The fluid fittings for the fuel valve were installed. 6. F-12108B was riveted.
06/18/19: 1.5Hrs Step 2 was reworked because of a change to the FLF-00013.
