GA Aerospace’s Web Site
Date:  10-18-2018
Number of Hours:  38.79
Brief Description:  23iS/U-07
10/16/2018: 3:41Hrs
1. F-1202L was riveted to F-1202E on both sides.
Worked on step 2.
10/17/2018: 17.86
2. The skins were clecoed and aligned to the longeron and to F-01234, they're were clamped afterwards.
3. The longerons were match-drilled using the skins and F-01234, the holes on F-1270D and F-4. 1270A were also match-drilled.
5. The holes on F-1270D were countersunk #30 120°, 13 on each side.
6. The nuplate holes around the triangular hole on the skins were dimpled and nutplates were riveted to them.
10/18/2018: 17.52
7. The skins were riveted to the fuselage.
8. F-1256 L&R were riveted to the skins.
