GA Aerospace’s Web Site
Date:  7-29-2019
Number of Hours:  6.33
Brief Description:  47iS/U-09, 47iS/U-10, 50iS/U-10, 50iS/U-13
47iS/U-09:
Tool-00002 and the iPhone previously zeroed with the canopy deck were used to pitch the propeller blades. Several readings were taken until the angle hit 71.2 degrees. with a variation to 71.1, this was done for both propellers in order to assure the angle difference was not bigger than .1 degrees. After torquing the bolts, the pitch was re-checked.
47iS/U-10:
The spinner and the spark plugs were reinstalled.
50iS/U-10:
Worked on installing the air filter
50iS/U-13:
FF-00091A was connected to Vent-00003.
