1. Pay close attention to the way the skins should go, use logic to figure out this as well, remember that the way these overlap should prevent water from going into the assembly .
2. N/A
Page 38iS/U-15:
1. If you are not going to work with these right now, you should either prime them right now or keep them in their bag, otherwise they’ll start to rust
NOTE: We also reported to Van’s that the stabilator cables don’t have bushings all throughout the holes, they don’t need, to since the cable should be really tense and will not touch the bulkhead.
