We worked on page 36A-07 and did the steps 3 to 6. When the resin was fully cured we removed the fairings and cleaned the area of the excess resin, then clecoed the parts together and made the three final drill #27, removed the clecos and installed the nutplates, after attaching the hardware of the three holes, we did the other six final drill #27 and put the nutplate. To install the fairing, we must do the countersink in the other part of the fairing. When we work with fiberglass this is preferable when countersink is deep, because prevent damage between both pieces. In the step 6 we mounted the fairing. All the steps in the page 36A-07 is for both fairing.
