We worked on page 36A-06 and performed steps 2 to 4. We installed both fairing and marked with a point pen the necessary distanc to have clearance between the inboard and outboard side of the wheel. The clearance distance is approximately ½”. Once the parts were marked we had to remove and trim the material, then, with a sand paper we finished the parts, and reinstalled to check that the wheel opening was proper. On page 36A-07 we performed steps 1 and 2. Made the final drill #19 on the fairings and then roughen the inside of the U-0001A and U-00001B on the screw holes #19. We put grease on screws, U-0002 and applied the resin. After applying the resin on the fairing we reinstalled while the mixture was wet. Because the parts were wet, we could not use them. We worked on page 36A-11 and did part of the step 2 and the step 5 and 6. We separated the part U-00006E-R-1 & L-1, after separating we did the countersink in the rivet holes. On the following step, we had to remove the area and finished with sand paper. We finished the step 1 of page 35iS/U-02, we drilled #3/8” then we installed the engine mount standoff with the indicated hardware.
