Members: Daniel Martinez, Jose Guerrero, Ismael Romo
Van's answered and said that we could flatten the part (mentioned in yesterday'92s log) and flute again, we did that and with this we continued with step 5 (18-06). The only problem that we found on this step was some rivets that had a bit of a gap on the forward side of the flaperon since that part is rounded, we had to remove 3 rivets and placed them again, make sure to remove the rivet stem that may be left inside the flaperon. For step 6 (18-06) notice that figure 2 does tell you how much you have to screw the rod-end beearings, 11/32 from surface to center, to measure this we did some calculations and used a vernier. With the right flaperon completed we proceeded with the left one and did all steps of page 18-04 except the ones that require the A-1201C skin (which is the one that we previously damaged) Again with the same method of bucking (see log from 4/24) we started step 1 (18-05) but we couldn't complete it because we had to re-prime the pivot brackets.
