02/10/20: 0.8Hrs 46iS-11 1: The magnetic plug was safety-wired to the crankshaft plug screw. Worked on step 2
02/11/20: 0.68Hrs 2: The oil pressure regulator plug was safety-wired to the engine pump housing. To do so, the radiator had to be semi-removed. 3: The oil tank drain plug had already been previously safety-wired.
