42MiS/U-04 AV-00008 was installed onto the fuselage.
42MiS/U-08 The ELT antenna was temporarily installed in order to route the cable, the surface in which the antenna will be finally installed has to be free of paint in order to be ground. The SB437-4 bushing was installed.
42MiS/U-20 F-00034A and F-00034-R were installed to the fuselage but the holes through which the screws would go, had to be opened #19. Wires were tie-wrapped to their respective ES-00301.
42MiS/U-24 The coax cable for the AV-0008 COM antenna was connected.
42MiS/U-28 Step 3 was completed by installing all of the plastic necessary bushings.
