39iS/U-06: The Canopy latch was finally latched after installing our custom latch block, It's working perfectly.
39iS/U-12: The steps of this page required to install the interior and exterior latches and add shims to the block as needed to make sure it'll get out of place on its own. It wasn't required for us.
42MiS/U-08: The pending bushing on step 9 was finally installed.
42MiS/U-10: The roller was cut of the E22-50K. The roll bar brace was drilled #19 and the circumference of the hole was sanded to remove paint and primer. The spade terminal of cable F6035 was connected to the COM spade on the switch.
42CiS/U-11: The Aft pitot line from the empennage and the pitot line from the pitot tube were routed to the panel base making sure they were free of bends. Both lines were trimmed and connected using the FLF-00023 connector.
