GA Aerospace’s Web Site
RV-12iS A
47iS-02, 47iS-03, 47iS-04
47iS-02:
1: NA
2: NA
3: NA
4: Tutorial to safety wire the caps can be found on YouTube.
5: 118 degrees appear to be the standard angle for drill bits, the grinder has a set-up at that angle.
6: We started tapping with a tap die, and continued with the screw.
47iS-03:
1: NA
2: NA
47iS-04:
1: NA
2: The material should be removed very carefully because the bottom part of it needs to be saved.
RV-12iS B Home
RV-12iS A Home
3504
Batteries Log
612
885
Inventory
PAP
Powerplant
Service Bulletin
Training (Emp. Team)
Training (Fus. Team)
25
336
Training (Wings Team
