Brief Description: Page 24iS/U07 and /U-02 performed
Today, step 3 24iS / u-07 was performed in which match drill # 30 all holes common between the skin was made F-01270-L-1 & -R-1, F-01270A-1, F-1270D and F -01255-L-1 & -R-1, and also match-drill # 30 all holes common between F-01205B-L-1 & -R-1 and F-01255-L-1 & -R-1.
Steps 5, 6, 7 24iS / U-02 were also performed, in step 5 final drill # 30 was made to the holes that were # 40 this step was carried out starting from the holes of the center outwards and placing a cleco in every hole made. The step 6 was performed, in which, we made match drill # 30 the three holes of the C-0123A through the F-1231A-FR & FL and uderlying F-12313. Finally in step 7 the parts were disassembled and each hole was burned with the exception of the surface of the holes where the countersink will later be made.
