Today, steps 1 to 5 23iS / U-09 were performed in which 2 10-inch hinges were cut, in this step it is necessary to be careful whilencutting them because the parts as shown in figure 4 show that both They are mirror one of another. also 2 Spacer of 10 inch each one were cut, these will be placed behind the hinges. in step 3 a hole was made to the hinge with the specific measures which will be used as a guide for the installation of the hinges. Steps 1 to 5 23iS / U-08 were also carried out, here the parts F-1086 and F-1087 were separated. The parts F-1087A, F-1092 and F-1093 were also assembled, installed with rivets AN426AD3-4. Steps 1 and 2 23iS / U-02 were performed in which they were fastened with clecos the pieces F-1231B & C, F-1231E to F-1231A-FL & -FR. In this step it is necessary to deburr the edges in both pieces so that they eliminate the possible gap between them and achieve the correct assembly.
