GA Aerospace’s Web Site
Date: 4-14-2018
Number of Hours: 24.00
Brief Description: Pages 21iS/ U-08, U-10
Team: Alvaro Lopez, Angel Rodriguez, Juan Isiordia
abscent:0
Step 1 of page 21iS / U-08 was performed, 2 nutplates k1000-08 were installed on each piece F-01242L & R.par step 2 21iS / U-08 was carried out, which consisted on making dimpling in the # 40 holes of the nutplates along with the # 5 rib.par step 4 21iS / U-08 was also carried out in which countersink was made to holes # 30 indicated in piece F-1252.par Step 5 21iS / U-08 Consisted on riveting the part F-01242-R, F-1252 and the pulley bracket assembly was carried out.par step 6 21iS / U-08 was made, which consisted in riveting the rib 6 to the pulley bracket assembly using 7 rivets LP4-3 and the manual riveter.
step 7 21iS / U-08 was carried out, consisting of making dimpling in the holes of the K1000-03 nutplates and those of the 4 rib, to later rivet both using rivets AN426AD3-3.5.
Step 8 21iS / U-08 was made which says to rivet the pieces F-01242-L, F-1252 and the Flaperon Mixer Arma Assembly in the rib 4 using 2 rivets CS4-4 in the piece F-1252 and LP4-3 in the rest.
Step 9 21iS / U-08 was completed. Rib # 3 was riveted to the Mixer Arm Assembly flaperon using LP4-3 rivets.
step 1 of page 21iS / U-10 was carried out, which consists in doing dimpling # 30 in the 4 holes with aft flanges orientation, in both parts F-01225-L-1 & R-1.
Step 2 21iS / U-10 was carried out, which claims to rivet nutplates K1000-08D with rivets AN426AD3-3 together with parts F-01225-L-1 & R-1. Step 3 was also carried out, which consists of separating the piece F-1253 removing the hatched areas, using the tape closure.
Finally step 4 21iS / U-10 was performed, in which the piece F-01225-L-1 was riveted to the rib 1 and the Flaperon Mixer Bracket Seat Rib assembly with rivets LP4-3.
