GA Aerospace’s Web Site
Date: 3-17-2018
Number of Hours: 24.00
Brief Description: Page 21iS / u-07
Step 10
Team: Eduardo Duran, Andrea Limon, Alma Elguezabal
Abscent:0
Page 21iS / u-07 Step 10: we finished riveting the pieces F-01219A-1 and the nutplates MK1000-428 with rivets AN426AD3-3.5. We added grease to the hardware indicated in the instruction, which we later use in step 11 joining it with the parts F-01219A-1 and B-1, 2 bushing of 1,250 in length and the bushing of 1,538 in length in part of step 12 that we also perform It is important to leave the rotation between the parts and the bushings.
Page 21iS / U-06 Step 1, 2, 3 and 4 is to separate / cut the pieces F-01299 , F-1216, F-00122 and F-00123AB in equal parts, we do it with a saw and a black disc burner.
Step 5: Label the ribs F-01215L-1 and R-1 from 1 to 8, since each one has specific steps and it is essential to identify them by number to follow the instructions correctly.
Step 6: Remove the vertical area that indicates the plane in each of the ribs with a scissors to cut the metal and with a rebabador we eliminate the edges and polish the cuts.
Step 7: place the cubes in the piece F-01299L to the rib 4 and verify that nothing is obstructed in the elongated hole. We repeat the step for the rib 8. Then we join the rib 1 with the piece F-01299-R, we repeat the step for the rib 5.
Step 8: place the cubes to the piece f-00123 and F-00122, then we made a countersink # 40 on the piece F-00123 On the opposite side that indicates the plane. After joining these pieces with rivets AN426AD3-4 and join it to the coast 1. We repeat the step on coast 1 using a wedge. When performing step 8 you can use it as a bad rivet, which was extracted with the techniques learned and placed a new one correctly.
FLAPPERON MIKER ARM ASSY
RIVETING RIGHT SEAT RIB
RIGHT SEAT RIB ASSY
