Cut the Upper Bearing (7F7-4C) to the right dimensions. Filed a radius on the front side to fit under the Upper Channel.Layed out the slots for the Steering Rods. Drilled several holes and cut the slots with snips.Drilled a 2" diameter hole on the Front Lower Bearing (7F8-5). Open the thiner end to 2".
