Deburred and applied Cortec to the mating sides of the Bottom Channel (7F6-1) and the Rear Torque Tube Bearing (7F6-2). Riveted together with 22 A4 rivets.Attached a vertical wooden piece to suppot the passenger side skin. Attached the passenger side skin to the bottom skin using clecoes and a bracket on the vertical wooden piece.Clecoed the two bulkheads to the bottopm sking and clamped them to the passenger side skin. Bent the "L" angles tips on the side skin and bottom skin to fit together and clecoed the ones on the bottom skin.
