Bobby's RV-10 Build
Date: 12-9-2017
Number of Hours: 0.00
Brief Description: Avionics Daydream
Started thinking about my panel and avionics, because THAT's right around the corner. Not!
Configuration is based on GoodPlaneLiving's RV-10. Prices are from Sarasota Avionics.
Ouch. Going to have to pare this back a bit to start I think.
Total: $37,739 1 GDU 465 $4,400 G3x Touch MFD w/SXM 2 GDU 460 $3,900 G3x Touch PFD 3 GDU 460 $3,900 G3x Touch MFD 2 4 GDU Inst. $195 (3) GDU Install Kits 5 G3x LRU $1,500 ADAHRS, Magnetometer, OAT Probe, Config Module 6 GSU 25 $65 ADAHRS Connector Kit 7 GMU11 $30 Magnetometer Install Kit 8 GMU Mount $85 Magnetometer Mount 9 GMC 307 $1,100 (Optional) Autopilot Interface 10 Install Kit $25 GMC 307 Install Kit 11 GSA 28 $2,250 (3) Autopilot Servos 12 Servo Conn $90 (3) Servo Connector Kits 13 Install Kit $150 Roll&Pitch Servo Install Kits 14 Install Kit $750 Yaw Servo Install Kit 15 GEA 24 $600 Engine Information System 16 GEA Conn $125 EIS Connector Kit 17 GEA Sens $1,250 EIS Sensors 18 RPM Sens $90 Hall Effect for Bendix Mags 19 Carb Temp $70 Carb Temp Sensor 20 GAP 26 $450 Heated Pitot (regulated) 21 GI 260 $250 AoA Indicator 22 GMA 245 $1,325 Audio Panel 23 GTN 625 $5,500 Optional GPS Nav 24 GTX 345w $4,990 ADS-B Xponder w/WAAS 25 GAD 27 $500 Control Interface Adapter Unit 26 GAD Conn $85 GAD 27 Connector Kit 27 GAD 29 $425 GPS/Nav Interface Adapter 28 GAD Conn $50 GAD 29 Connector Kit 29 VP-X Pro $2,195 Vertical Power Electronic Circuit Breaker 30 VPX Harness $595 VP-X Wire Harness 31 VPX Conn $215 VP-X Connector Kit 32 VP-X Mount $160 VP-X Mounting Tray 33 GA 26XM $95 SXM Antenna 34 GA 35 $329 GPS/WAAS Antenna
Aerosport panel in approximate GoodPlaneLiving configuration
All I want for Christmas
