Bobby's RV-10 Build
RV-10
Ordered Tools
Ordered most of the RV-10 Tool Kit from Aircraft Spruce.
Qty Ship B/O Item Unit Price Total Price
1 1 0 12-00609 VICE GRIP FLUTING PLIER 52.750 52.75
1 1 0 12-00611 AVERY VISE GRIP DIMPLER 3/32" 52.750 52.75
1 0 1 12-00613 AVERY POP RIVET DIMPLER 3/32" 25.850 25.85
1 1 0 12-00618 AVERY BACK RIVETING PLATE 68.750 68.75
1 1 0 12-00622 AVERY SPEED DEBURR-C'SINK TOOL 37.650 37.65
1 1 0 12-00629 AVERY DOUBLE EDGE DEBURR TOOL 23.650 23.65
1 1 0 12-00631 AVERY SHOP HD RIVET GAUGE SET 22.750 22.75
1 1 0 12-00741 AVERY FLUSH SWIVEL RIVET SET 49.500 49.50
1 1 0 12-00867 AVERY 4PC DRILL STOP SET 10.900 10.90
1 1 0 12-00868 AVERY DELUXE DIMPLE DIE KIT 219.750 219.75
1 1 0 12-00873 AVERY 1/8" DBL OFFSET RIVET ST 29.500 29.50
1 1 0 12-00875 3M SCOTCH BRITE DEBURR WHL 7A 85.750 85.75
1 0 1 12-00876 AVERY CUT/POLISH WHEEL KIT 63.750 63.75
1 1 0 12-00879 AVERY #40 X 3/8" CSNK CUTTER 12.950 12.95
1 1 0 12-00880 AVERY #30 X 3/8' CSNK CUTTER 12.950 12.95
1 1 0 12-00881 AVERY #20 X 1/2" CSNK CUTTER 12.950 12.95
1 1 0 12-00884 AVERY 1/4" COBALT DRILL BIT 5.350 5.35
1 1 0 12-00885 AVERY #12 COBALT DRILL BIT 2PK 7.500 7.50
1 1 0 12-00886 AVERY #19 COBALT DRILL BIT 2PK 5.350 5.35
1 1 0 12-01077 A1006-234X RETAINER SPRING BEEHIVE 6.500 6.50
1 1 0 12-01079 A1007-234X RET SPRING QUICK CHANGE 4.650 4.65
250 250 0 12-01138 SHEET HOLDERS M-1/8 CLECO C-18 0.570 142.50
10 10 0 12-01139 SHEET HOLDERS M-3/16 CLECO 0.650 6.50
500 500 0 12-01140 SHEET HOLDERS M-3/32 CLECO 0.553 276.50
10 0 10 12-01141 SHEET HOLDERS M-5/32 CLECO 0.640 6.40
10 10 0 12-01143 SIDE GRIP CLAMPS P/N SC-1/2-1 2.250 22.50
10 10 0 12-01161 1/2" X 1/2" SIDE GRIP CLAMP 1.950 19.50
1 1 0 12-01205 STRAIGHT RIVET SET 1/8X 3-1/2 16.850 16.85
1 1 0 12-01298 BUCKING BAR 1-3/4 LB. 23.750 23.75
1 0 1 12-01412 AVERY MICRO-STOP CSNK CAGE 36.500 36.50
1 1 0 12-02005 3X RIVET GUN 139.950 139.95
1 1 0 12-02062 STEEL RULES #1216 8.950 8.95
1 1 0 12-02689 ECONOMY BUCKING BAR TYPE B 25.750 25.75
1 1 0 12-03900 UNIBIT STEP DRILL # 3 43.750 43.75
2 2 0 12-04
RV-10 Home
118
Elevator
Horiz. Stabilizer
Priming Interior
Shop
Vertical Stabilizer
