My original design called for only a push button start switch. However I took some advice and added a keyed switch in the starter circuit When the key is off no power to the start button is available. When to key is on the Start Button lights up green to signal that the start circuit is active.
Image 3 shows the lighted push button switches that interface with the Master Power Board.
