Brief Description: New right side canopy front cap strip
Remade right side canopy front cap strip due to less than perfectly tight fit. Installed and filed both cap strips to fit front edge of plexi. Cut both to 7/8" wide and reinstalled. Checked windscreen fit again and drilled JRW Tipper canopy front bearing mounts in place. Cut front roll bar support brace to length and drilled holes for upper AN$ bolt per plans. Noticed that edge distance for front (lower) roll bar brace hole was only 1/4". Spec = 3/8". Called Ken at Van's - he said no problem for welment. Can add 3RD AN3 if desired. Wildo
