Brief Description: Finish Right HS Riveting Start Rear Spar
Linda and I finished the Right Horizontal Stabilizer riveting. Started riveting rear spar to L/R HS assembly per instructions using pnuematic squeezer. Found minor misalignment of left lower rear skin to left lower rear spar holes. Cleaned up with #40 reamer. Mostly cut primer. Rivets went in straight with no problems. All other holes lined up perfectly. Still have to complete rear spar rivets and HS404-405 and HS706 rivet squeezing.
