Brief Description: Right and Left HS inner nose and inner rib drilli
Finally got the #30 and #40 drill collets fron Cleavland. Cut 12" #30 drill to 10". Drilled Right and Left HS inner rib flange holes according to instructions. Used 10" #30 drill bit in right angle adapter to get proper alignment of holes. Worked fine.
