Flew the Mooney yesterday, so no work on the 27th. Great weather. Checked out Boulder City, Henderson, and back to Sky Ranch for currency. Drilled rib to spar attach holes except HS 708. Clecoed right side skin to skeleton and prepared HS404 and 405 ribs. Clamped in place. Noticed a "bump" in the skin on one side, and a low spot at the corresponding location on the other side. Traced to misaligned HS707 center nose rib. Apparently Van's holes in wrong spot for right side (left side OK).
